Install Cable Management Arm
The cable management arm (CMA) is an optional assembly that you can use to route the server
cables in the rack.
Unpack the CMA parts.
Take the CMA to the back of the equipment rack and ensure that you have adequate room to work
around the back of the server.
Note -
References to “left” or “right” in this procedure assume that you are
facing the back of the equipment rack.
Remove tape to separate the parts of the CMA.
Insert the CMA's mounting bracket connector into the right slide-rail until the connector
locks into place with an audible click.
1
CMA mounting bracket
2
Right slide-rail
Insert the right
CMA slide-rail connector into the right slide-rail assembly until the connector locks
1
2
Right slide-rail
Insert the left CMA slide-rail connector into the left slide-rail assembly until the connector
1
2
Left slide-rail
Install and route cables to your server, as required.
If required, attach the
cable hook and loop straps to the CMA, and press them into place to secure the
cables.
Note -
Cable hooks and loop straps are preinstalled on the CMA. Perform this step if you need to
reinstall cable hooks and straps on the CMA.
For best results, place three cable straps, evenly spaced, on the rear-facing side of the CMA
and three cable straps on the side of the CMA nearest the server.
1
CMA cable strap
2
CMA arm
