Language
Select from the list of available languages for the OS.
English*
Locale
Select your geographic region from the list of available locales.
Terminal
Select the type of terminal that you are using from the list of available terminal
types.
Network connection
Is the system connected to a network?
DHCP
Can the system use Dynamic Host Configuration Protocol (DHCP) to configure its network
interfaces?
If you are not using DHCP, note the network address:
IP address
If you are not using DHCP, supply the IP address for the system.
Example: 192.168.100.1
Subnet
If you are not using DHCP, is the system part of a subnet?
If yes, what is the netmask of the subnet?
Example: 255.255.255.0
255.255.0.0*
IPv6
Do you want to enable IPv6 on this machine?
Host name
Choose a host name for the system.
Kerberos
Do you want to configure Kerberos security on this machine?
If yes, gather this information:
Default realm:
Administration server:
First KDC:
(Optional) Additional KDCs:
Name service
Name service
If applicable, which name service should this system use?
Domain name
Provide the name of the domain in which the system resides.
DNS or NIS
NIS+ and NIS
If you chose NIS+ or NIS, do you want to specify a name server, or let
the installation program find one?
If you choose NIS:
DNS
If you chose DNS, provide IP addresses for the DNS server. You must enter
at least one IP address, but you can enter up to three addresses.
You can also enter a list of DNS domains to search when a DNS query is made.
Search domain:
Search domain:
Search domain:
LDAP
If you chose LDAP, provide information about your LDAP profile.
Profile name:
Profile server:
If you specify a proxy credential level in your LDAP profile, gather the following
information:
Proxy-bind distinguished name:
Proxy-bind password:
Default route
Do you want to specify a default route IP address, or let the OS installation program find
one?
The default route provides a bridge that forwards traffic between two physical networks. An IP
address is a unique number that identifies each host on a network.
You have the following choices:
You can specify the IP address. An
/etc/defaultrouter file is created with the specified IP address. When the
system is rebooted, the specified IP address becomes the default route.
You can let the OS installation program detect an IP
address. However, the system must be on a subnet that has a router that advertises itself
by using the Internet Control Message Protocol (ICMP) for router discovery. If you are using the
command-line interface, the software detects an IP address when the system is booted.
You can select None if you do not have a router or do not want the
software to detect an IP address at this time. The software automatically tries to detect
an IP address on reboot.
Specify one
Detect One
None*
Time zone
How do you want to specify your default time zone?
Geographic region*
Offset from GM
Time zone file
Root password
Choose a root password for the system.
