Go to main content
Sun Server X4-4 HTML Documentation Collection
Exit Print View
Updated: October 2015
Install a Power Supply
This procedure describes how to install a power supply (PSU). When installing a PSU, ensure that the pawl near the hinge of the latch engages the slot in the sidewall of the PSU bay. The pawl supplies the necessary leverage to seat the PSU connector with the PSU backplane.
The correct power supply for the Sun Server X4-4 is the A239C model.
Caution
Caution  -  System overheat and shut down. Installing the incorrect model of power supply can cause the server to over heat. Install only the supported model.
Before You Begin
  1. If necessary, remove the failed power supply. See Remove a Power Supply.
  2. Prepare the server for service. See Prepare the Server for Hot Service.
    To perform a cold-service procedure, see Prepare the Server for Cold Service.
  3. Ensure that the power supply handle is in the open position.
  4. Align the power supply with the empty power supply bay.
  5. Slide the power supply into the bay until it stops.
  6. To seat the power supply, rotate the release handle upward until it locks in place.
    Note -  The pawl at the hinge of the handle must engage the slot at the bottom of the power supply bay.
    This action of rotating the handle upward draws the power supply into the server and engages it with the internal connector.
    image:A multistep illustration showing how to install a power supply in the server.
  7. Connect the AC power cord to the power supply.
  8. Verify that the AC Present indicator is lit.
    For more information, see Power Supply Reference.
  9. Verify that the following indicators are not lit:
  10. If you performed a cold-service procedure, power on the server.
