Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: September 2021
Check the SuperCluster Virtual Assistant Version
The SuperCluster Virtual Assistant is available on SuperClusters with the latest versions of software enhancements. The assistant is part of the osc-domcreate package.
Perform this task to see if the assistant is available on SuperCluster and to identify the version of the assistant.
  1. On the management network, log into the control domain on the first compute server.
  2. Use the pkg info command to display the version of the assistant.
    In the output, the value for Branch indicates the version of the assistant. For example:
    # pkg info osc-domcreate
           Summary: Oracle SuperCluster IO Domain creation tool
       Description: Oracle SuperCluster IO Domain creation tool
             State: Installed
         Publisher: exa-family
           Version: 0.5.11
            Branch: 3.0.0.1803
    Packaging Date: April 24, 2019 at 11:36:58 PM
              FMRI: pkg://exa-family/system/platform/supercluster/osc-domcreate@0.5.11-3.0.0.1803:20190325T233658Z
    Note -  If the pkg info command does not return any package information, the assistant is not installed on your system.
Related Information
