Use this procedure to generate an XML file that will be used to provide database configuration information during the database installation.
These instructions assume that you have already performed these activities using the SuperCluster Virtual Assistant:
Created two or more Database I/O Domains (for more information, see Create a Database I/O Domain).
Deployed two or more Database I/O Domains (for more information, see Create a Database I/O Domain).
Created two or more zones on Database Zone Domains (for more information, see Configuring Zones).
At this point, you have created and deployed Database I/O Domains or Database Zones, but have not set up the storage servers or the database software on the Database I/O Domains or Database Zones.
See Configure the Assistant With Added Storage Servers (Administrators).
If you have multiple database zones that are part of a single RAC, select those zones as shown below.
A screen appears, asking where you want to save this configuration file. This action creates a configuration file that is later used by the config.sh command to install the database.
By default, the configuration file is named joc_import.xml. Rename this configuration file with a unique name to distinguish it from other configuration files.
Go to Start OEDA.
