Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: September 2021
View Network Resources
Use this procedure to identify the network resources and VLAN tags for each network. Both administrators and users can perform this task.
Note -  Fibre channel interfaces are supported starting with Super Cluster Virtual Assistant version 2.2.0.873. See Check the SuperCluster Virtual Assistant Version, Assign Fibre Channel Addressesand Support for Fibre Channel Interfaces in Domains.
  1. Access the SuperCluster Virtual Assistant.
    See Log In to the SuperCluster Virtual Assistant.
  2. In the navigation panel, select Network Resources.
    Tip  -  Only administrators have access to the Add and Edit buttons.
    image:Screen shot showing the Network Resources screen.
  3. Review the network parameters assigned to each network.
    The networks listed in the top table are the initial networks that were created when SuperCluster was installed. You cannot change these networks.
    The second table displays the additional networks that were added to provide network resources for I/O Domains. Users with the administrator role can add to and edit these networks. See Add or Edit a Network (Administrators).
    Multiple networks can exist for a given network type. For example, you can configure two management and two client networks.
  4. To view all the IP addresses for a network, click View in the Details column.
    image:Screen shot showing the network details screen.
  5. Consider your next action.
