Before creating a domain, the system administrator must ensure that these requirements are met:
Oracle personnel completed the initial software installation, configuration, and created Root Domains as specified in your configuration worksheets.
Refer to the Oracle SuperCluster T5-8 Owner’s Guide, the Overview Guide for your model (for example, Oracle SuperCluster M8 and SuperCluster M7 Overview Guide), and your configuration worksheets.
(Only applicable for SuperCluster version 2.6 or earlier) The CPU and memory resources for a dedicated domain are configured as needed using the osc-setcoremem tool. After the domains are created, you cannot change resources using the osc-setcoremem tool.
The Oracle SuperCluster Virtual Assistant must be available on SuperCluster. See Check the SuperCluster Virtual Assistant Version.
To initialize the assistant, you must have access to the XML file that describes the configuration of your system. Obtain the name and location of this file from your Oracle representative.
You must provide additional IP addresses for the domains. See Minimum Number of IP and Alt MAC Addresses.
Your browser must support secure SSL protocols (TLS version 1.2. or higher). Ensure that you are using the latest version of your browser.
Additional required information is needed for each I/O Domain that is created. For those details, see Required Information for Configuring I/O Domains.
