Use this procedure to edit a resource or network recipe. Any changes you make to a recipe are only reflected in future domains that are created using this recipe. The changes are not reflected in domains that are previously created based on the recipe.
Go to the Administrative Task Overview – See Administrative Task Overview.
Go to the next task – See Delete a Recipe.
