As of SuperCluster version 3.0, this feature is no longer available. The following procedure applies to SuperCluster version 2.6 or earlier.
Oracle VM (OVM) templates enable you to deploy a fully configured software stack using preinstalled and preconfigured software images.
Before you can create domains using an OVM template, you must upload the template into the assistant. After the template is available, users can select the template during the domain creation process, which results in domains with a preconfigured OS and application. The templates in the assistant can be used repeatedly to create domains.
Only users with the administrator role can perform this procedure.
This table provides additional OVM template resources.
For more information about OVM templates, go to: https://www.oracle.com/virtualization/technologies/virtual-appliances.html
Save the template in a location that is accessible as a file from the master control domain of SuperCluster.
The template requires several minutes to upload. After the template is uploaded, you can create domains using the template.
In the assistant, watch for a message similar to this example:
The template from file file:///var/tmp/ovmt/OVM_S11.3_WLS12.1.3_SPARC_SCRIPT_B4.ova is being added. This may take several minutes.
In the master control domain, type:
root@etc4m-appadm0101:~# ps -ef | grep ovm | grep -v grep root 47826 47825 0 19:15:36 ? 0:00 ksh /opt/oracle.supercluster/osc-ovmt/osc-ovmt -i file:///var/tmp/ovmt/OVM_S11. root 47822 646 0 19:15:36 ? 0:00 /usr/bin/python /opt/oracle.supercluster/osc-domcreate/iodine/iodine/ovmt.py -a root 47914 47826 0 19:15:38 ? 0:00 /opt/oracle.supercluster/osc-ovmtutils/ovmtlibrary -c store -o file:///var/tmp
Configure a domain with an OVM template – See Create an I/O Domain With an OVM Template (Deprecated).
Go to the Administrative Task Overview – See Administrative Task Overview.
Go to the Domain Configuration Task Overview – See Domain Configuration Task Overview.
View domains – See View I/O Domains.
