When you configure an domain, iSCSI LUN resources are automatically allocated. The assistant starts with a predefined amount of storage, then calculates additional resources for swap and dump based on the chosen CPU and memory resources.
If you deploy a domain using an OVM template, the template determines the amount of allocated iSCSI LUN resources.
For non OVM template-based Domains, the assistant approximately allocates these rpool resources, based on the type of domain and the version of the assistant:
