Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: September 2021
Delete a Recipe
Use this procedure to delete a recipe. Any domains that were created with the deleted recipe are unaffected.
  1. Access the SuperCluster Virtual Assistant.
    See Log In to the SuperCluster Virtual Assistant.
  2. In the navigation panel, select Recipes.
  3. Select the recipe you want to delete and click Delete.
  4. Click Yes.
  5. Consider your next action.
