Remove the PDB Signal Cable
Removing a cable is a cold-service operation. You must power off the server before you remove the cable.
Determine which cable to remove.
See Cable Configurations.
Prepare for service.
See Preparing for Service.
Review this information and complete these prerequisites in this order.
See:
Disconnect the cable from the PDB and the motherboard.
Set the cable aside.
Consider your next step.
