Removing the PDB is a cold-service operation. You must power off the server before you remove the PDB.
See:
Remove both power supplies.
Remove all fan modules.
See Servicing the Motherboard for cautions. For this service procedure, you are not removing the motherboard. You are moving it slightly so that you can remove the PDB.
See Install the PDB.
