Servicing the PDB
The PDB is an interconnect between the power supplies and the motherboard. The PDB is located forward of the power supplies, under the PSU duct. See Identifying Components.
Replace a faulty PDB.
Remove the PDB as part of another component's service
operation.
Install the PDB as part of another component's service
operation.
Determine if the PDB is faulty.
