Servicing PCIe Cards
PCIe cards provide additional I/O and other functionality. The PCIe cards install into the card slots located across the rear of the server. See Component Locations (Motherboard, Memory, and PCIe Cards). Additionally, there is an internal HBA PCIe card. See Servicing the Internal HBA PCIe Card.
 | Caution -
Ensure that all power is removed from the server before removing or installing PCIe cards, or damage to the PCIe cards might occur. You must disconnect all power cables from the system before performing these procedures.
 | Caution -
Disconnect any external cabling to a PCIe card prior to removing the card.
Replace a faulty PCIe card.
Remove a PCIe card as part of another component's service
operation.
Install a PCIe card as part of another component's service
operation.
Identify I/O connections.
Determine device NAC names.
Add PCIe cards.
Decrease the number of PCIe cards.
Identify a faulty PCIe card.
