Servicing the eUSB Drive
 | Caution -
These procedures require that you handle components that are sensitive to static discharge. This sensitivity can cause the component to fail. To avoid damage, ensure that you follow antistatic practices to Prevent ESD Damage.
 | Caution -
Ensure that all power is removed from the server before removing or installing an eUSB drive, or damage to the drive might occur. You must disconnect all power cables from the system before performing these procedures.
The eUSB drive provides USB 3.0 connectivity at the rear of the server. See Component Locations (Storage, Power, NVMe, and Fan Modules).
Replace a faulty eUSB drive.
Remove a eUSB drive.
Install a eUSB drive.
