Installing the PDB is a cold-service operation. You must power off the server before installing the PDB.
The bus bars are forward and down.
See Servicing the Motherboard for cautions. For this service procedure, you are not removing the motherboard. You are moving it slightly so that you can remove the PDB.
See Install the Fan Tray.
See:
See:
