Perform this task when you have previously removed the fan tray.
See:
![]() | Caution - The fan tray goes inside the latch line of the cable pass through. Take care when installing the fan tray so that the cable pass through is not damaged or unseated. |
![]() | Caution - The fan tray sits on top of the cable pass through. The cable pass through needs to be properly seated when installing the fan tray. If not, damage may occur to the latch. |
Two arrows on the top of power supply bay show where the fan tray aligns. Holes in the base of the tray need to match up with fan connectors. If necessary, rotate the tray 180 degrees to align.
Verify that the fan tray is properly seated, and the top surfaces of the fan tray are flush with the server.
See Install a Fan Module.
See Component Service Task Reference for assistance.
