Install the USB Board
Installing the USB board is a cold-service operation. You must power off the server before installing the USB board.
Consider your first step.
Connect the cable to the motherboard and the USB board.
Review this information and complete these prerequisites in this order.
See:
Position the USB board to the location where it installs into the chassis.
The USB connectors are forward and upward.
Lower the USB board to the chassis, and slide the board forward over the alignment pin.
Compress the EMI shielding while you install and tighten the two screws.
Consider your next step.
Finish the installation procedure.
See Returning a Server to Operation.
