Verify the PDB
After you install the PDB, you can verify its functionality.
Access Oracle ILOM.
See Log In to Oracle ILOM (Service).
Reset the PDB.
-> set /SYS/PDB clear_fault_action=true
Are you sure you want to clear /SYS/PDB (y/n)? y
Set 'clear_fault_action' to 'true'
Verify that the PDB is no longer faulty, then return to this procedure.
See Determine if the PDB Is Faulty.
