puppet-help - Display Puppet help.
puppet help action
PUPPET-HELP(8)                   Puppet manual                  PUPPET-HELP(8)
NAME
SYNOPSIS
       puppet help action
OPTIONS
       Note  that any setting that's valid in the configuration file is also a
       valid long argument, although it may or may  not  be  relevant  to  the
       present action. For example, server and run_mode are valid settings, so
       you can specify --server <servername>, or --run_mode  <runmode>  as  an
       argument.
       See   the  configuration  file  documentation  at  https://docs.puppet-
       labs.com/puppet/latest/reference/configuration.html for the  full  list
       of acceptable parameters. A commented list of all configuration options
       can also be generated by running puppet with --genconfig.
       --render-as FORMAT
              The format in which to render output. The  most  common  formats
              are  json, s (string), yaml, and console, but other options such
              as dot are sometimes available.
       --verbose
              Whether to log verbosely.
       --debug
              Whether to log debug information.
ACTIONS
       help - Display help about Puppet subcommands and their actions.
              SYNOPSIS
              puppet help [--version VERSION] [subcommand] [action]
              DESCRIPTION
              OPTIONS --version VERSION - The version of  the  subcommand  for
              which to show help.
              RETURNS
              Short help text for the specified subcommand or action.
EXAMPLES
       help
       Get help for an action:
       $ puppet help
COPYRIGHT AND LICENSE
       Copyright 2011 by Puppet Inc. Apache 2 license; see COPYING
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |     ATTRIBUTE VALUE      |
       |Availability   | system/management/puppet |
       |Stability      | Volatile                 |
NOTES
       This     software     was    built    from    source    available    at
       https://github.com/oracle/solaris-userland.   The  original   community
       source  was  downloaded  from  https://github.com/puppetlabs/puppet/ar-
       chive/5.5.0.tar.gz
       Further information about this software can be found on the open source
       community website at http://puppetlabs.com/.
Puppet, Inc.                      March 2018                    PUPPET-HELP(8)
