Go to main content
マニュアルページ セクション 1: ユーザーコマンド
印刷ビューの終了
更新: 2018年8月8日
sccs-help(1)
名前
sccs-help, sccshelp - ask for help regarding SCCS error or warning messages
形式
/usr/bin/sccshelp [argument]...
説明
The sccs-help utility retrieves information to further explain errors messages and warnings from SCCS commands. It also provides some information about SCCS command usage. If no arguments are given, sccs-help prompts for one.
An argument may be a message number (which normally appears in parentheses following each SCCS error or warning message), or an SCCS command name. sccs-help responds with an explanation of the message or a usage line for the command.
When all else fails, try /usr/bin/sccshelp stuck.
ファイル
/usr/lib/help
directory containing files of message text
属性
See attributes(7) for descriptions of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
developer/build/make
関連項目
sccs-val(1), sccs(1), sccs-admin(1), sccs-cdc(1), sccs-comb(1), sccs-delta(1), sccs-get(1), sccs-prs(1), sccs-prt(1), sccs-rmdel(1), sccs-sact(1), sccs-sccsdiff(1), sccs-unget(1), what(1), sccsfile(5), attributes(7)
