-> show faulty Target | Property | Value --------------------+------------------------+--------------------------------- ->
If a fault is found, information about the fault is displayed under three columns:
Target – A numerical subtarget of the /SP/faultmgmt fault management instance. For example, /SP/faultmgmt/0/faults/0.
Property – FRUID-type properties or parameters of the faulted component or the fault itself. For example, FRU, class, MSGID, UUID, timestamp, and so on.
Value – The value of the property. For example, the IPMI name, fault class categorization, message ID, and so on.
This is an example of a faulty power supply:
-> show faulty Target | Property | Value --------------------+------------------------+------------------------------- /SP/faultmgmt/0 | fru | /SYS/PS0 /SP/faultmgmt/0/ | class | fault.chassis.power.fail faults/0 | | /SP/faultmgmt/0/ | sunw-msg-id | SPT-8000-MJ faults/0 | | /SP/faultmgmt/0/ | component | /SYS/PS0 faults/0 | | /SP/faultmgmt/0/ | uuid | d7d67b9b-ba67-e257-8d8d-bcef2db2 faults/0 | | 971b /SP/faultmgmt/0/ | timestamp | 2011-09-13/15:47:41 faults/0 | | /SP/faultmgmt/0/ | fru_part_number | 300-2304 faults/0 | | /SP/faultmgmt/0/ | fru_serial_number | C40003 faults/0 | | /SP/faultmgmt/0/ | product_serial_number | 1133BDN082 faults/0 | | /SP/faultmgmt/0/ | chassis_serial_number | 1133BDN082 faults/0 | | /SP/faultmgmt/0/ | detector | /SYS/PS0/PWROK faults/0 | | ...
