Installing a CPU is a cold-service operation. You must power off the server before installing the CPU.
See CPU Tool.
The triangle on the side of the tool aligns with pin 1 of the CPU.
You hear a click, and the release button retracts.
The triangle on the side of the tool aligns with pin 1 of the CPU socket.
![]() | Caution - The tool must be level and flat onto the socket, not offset or angled. |
![]() | Caution - Do not attempt to forcibly seat the CPU. |
The processor should lie flat in the socket, and be properly aligned.
The pressure frame should sit flat over the processor.
The “System Front” label must face the front of the server.
![]() | Caution - Moving the heat sink too much unevenly distributes the thermal compound and can lead to CPU damage. |
Alternate between the screws in an X pattern, turning each one-half revolution, until they are fully seated.
See Locate a Faulty CPU.
