Removing the PDB is a cold-service operation. You must power off the server before you remove the PDB.
If you have not prepared for service, do so now. See Preparing for Service.
If you are removing the PDB as part of another component's removal or installation procedure, go to Step 2.
Remove both power supplies.
Remove all fan modules.
Remove all DIMMs.
If you removed the PDB as part of a replacement operation, install a new PDB. See Install the PDB.
If you removed the PDB as part of another component's removal or installation procedure, return to that procedure. See Component Service Task Reference for assistance.
