In this illustration of the DIMM slots, the Oracle ILOM legacy targets for the DIMMs are provided across the top, and the Oracle ILOM /System targets for the DIMMs are provided across the bottom.
For example, the slot on the far left has the Oracle ILOM legacy target of /SYS/MB/P1/D0. This same slot has the Oracle ILOM /System target of /System/Memory/DIMMs/DIMM_0.
When you add or remove DIMMs to the motherboard, follow these guidelines:
You can configure an odd number of DIMMs, however an equally-balanced even number of DIMMs provides better performance.
When you add DIMMs in pairs, the pair should be of the same part number.
If you are mixing DIMM capacities, install the largest capacities first, then consecutively smaller capacities.
If a slot is empty, install a DIMM filler. With the single-processor configuration, all DIMM slots on P1 must be filled with filler panels.
![]() | Caution - Overheating hazard. There must be no empty DIMM slots. |
Populate the DIMMs in the order described in DIMM Population Guidelines for Dual-Processor Servers
