-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y
faultmgmtsp> fmadm faulty No faults found faultmgmtsp>
If a fault is found, information about the fault is displayed in seven fields:
Heading – The time, UUID, MSGID, and severity of the fault are displayed.
Fault class – A categorization of the fault according to the component and type of fault.
FRU – The Oracle ILOM target, part number, and serial number of the faulted component.
Description – A succinct statement of the fault.
Response – A description of how the system responded to the failure.
Impact – A description of the consequences if no service action is taken.
Action – Additional tasks the user can do to supplement troubleshooting the fault.
This is an example of a power supply fault:
------------------- ------------------------------------ -------------- -------- Time UUID msgid Severity ------------------- ------------------------------------ -------------- -------- 2011-09-13/15:47:41 d7d67b9b-ba67-e257-8d8d-bcef2db2971b SPT-8000-MJ Critical Fault class : fault.chassis.power.fail FRU : /SYS/PS0 (Part Number: 300-2304) (Serial Number: C40003) Description : A Power Supply has failed and is not providing power to the server. Response : The service required LED on the chassis and on the affected Power Supply may be illuminated. Impact : Server will be powered down when there are insufficient power supplies operational. Action : The administrator should review the ILOM event log for additional information pertaining to this diagnosis. Please refer to the Details section of the Knowledge Article for additional information.
faultmgmtsp> fmdump TIMESTAMP UUID MSGID 2011-12-20/06:00:14 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 2011-12-20/06:03:26 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 Repaired 2011-12-20/06:03:26 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 Resolved 2012-01-27/18:47:27 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 2012-02-16/16:54:08 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 Repaired 2012-02-16/16:54:08 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 Resolved 2012-03-06/20:13:05 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 2012-03-06/20:24:12 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 Repaired 2012-03-06/20:24:13 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 Resolved faultmgmtsp>
The fault history provides the date and time (TIMESTAMP) of the fault, the UUID, and the MSGID of the fault.
In this example, three fault events occurred as indicated in the MSGID column. When the fault was Repaired satisfactorily, Oracle ILOM marked the fault as Resolved.
faultmgmtsp> exit ->
