Installing a DIMM is a cold-service operation. You must power off the server before installing the DIMM. This procedure is the same for installing a DIMM filler.
If you are replacing a DIMM, remove the faulty or obsolete DIMM first, then return to this procedure, Step 3. See Remove a DIMM.
If you are installing a new or an additional DIMM, go to Step 2.
If you are installing a DIMM as part of another component's removal or installation procedure, go to Step 3.
Ensure that the notch in the DIMM lines up with the key in the slot.
If you installed a DIMM as part of a replacement operation, go to Step 8.
If you installed a DIMM as part of another component's removal or installation procedure, return to that procedure. See Component Service Task Reference for assistance.
If you have installed a new DIMM, go to Step 8.
