Removing a DIMM is a cold-service operation. You must power off the server before you remove the DIMM.
See Locate a Faulty DIMM.
If you have not prepared for service, do so now. See Preparing for Service.
If you are removing a DIMM as part of another component's removal or installation procedure, go to Step 3.
If you removed a DIMM as part of a replacement operation, install a new DIMM. See Install a DIMM.
If you removed a DIMM as part of another component's removal or installation procedure, return to that procedure. See Component Service Task Reference for assistance.
If you are not replacing the DIMM, install a DIMM filler in its place. See Install a DIMM.
![]() | Caution - Overheating hazard. There must be no empty DIMM slots. |
