Follow these guidelines when experiencing difficulty connecting to the server through its NET MGT port.
Ensure that the state property of the /SP/network Oracle ILOM target is set to enabled. For example:
-> set /SP/network state=enabled
Verify the integrity of the physical connection between the NET MGT port of the server, the network, and the management device.
Ensure that at least one of the appropriate network services are enabled in Oracle ILOM.
Use an industry-standard network diagnostic tool, like IPv4 Ping or Traceroute to test the network connections between the server and the management device.
