Installing a cable is a cold-service operation. You must power off the server before installing the cable.
Install all fan modules.
If you installed the cable as part of a replacement operation, go to Step 5.
If you installed the cable as part of another component's removal or installation procedure, return to that procedure.
See Component Service Task Reference for assistance.
