Removing a cable is a cold-service operation. You must power off the server before you remove the cable.
If you have not prepared for service, do so now.
If you are removing a cable as part of another component's removal or installation procedure, go to Step 3.
Remove all fan modules.
If you removed the cable as part of a replacement operation, install a new cable.
If you removed the cable as part of another component's removal or installation procedure, return to that procedure.
See Component Service Task Reference for assistance.
