1.
2.
Can you access Oracle ILOM?
Step 28
Step 3
3.
Are the communication parameters configured correctly?
Step 5
Step 4
4.
Correct the communication parameters. Then go to Step
1.
5.
Is the cabling wired correctly?
Step 7
Step 6
6.
Correct the cabling. Then go to Step 1.
7.
Is the supporting hardware functional?
Step 9
Step 8
8.
Fix the supporting hardware. Then go to Step 1.
9.
Check the server.
10.
11.
Are any power supply LEDs lit?
Step 13
Step 12
12.
13.
Do the power supply LEDs indicate a fault?
Step 14
Step 17
14.
15.
Does the power fault LED persist?
Step 16
Step 1
16.
17.
18.
Does the SP status LED indicate a fault?
Step 19
Step 21
19.
Reset the SP. Insert the end of a paper clip into the pinhole
between the video port and the SER MGT port, and press the
switch within. See Rear Panel Components (Service).
20.
Does the SP fault LED persist?
Step 40
Step 1
21.
22.
Do the chassis status LEDs indicate a fault?
Step 1
Step 23
23.
24.
Do the drive LEDs indicate a fault?
Step 1
Step 25
25.
26.
Do the network status LEDs indicate a fault?
Step 27
Step 1
27.
Inspect and replace cables as necessary. Then go to Step
1.
28.
29.
Do the log entries identify the problem?
Step 30
Step 34
30.
Is the problem identified as a hardware problem?
Step 32
Step 31
31.
The problem is software related. See Server Administration.
32.
Is sufficient information provided to justify a service
operation?
Step 33
Step 34
33.
34.
Is the server fully powered up?
Step 36
Step 35
35.
36.
37.
Do the general diagnostics identify any specific component as
faulty?
Step 38
Step 31
38.
39.
Does the component pass functional tests?
Step 31
Step 33
40.
