After you install a DIMM, you can verify its functionality.
-> set /SYS/MB/Px/Dy clear_fault_action=true Are you sure you want to clear /SYS/MB/P0/D7 (y/n)? y Set 'clear_fault_action' to 'true' ->
If you installed a new DIMM as part of a replacement operation, verify that the DIMM is no longer considered faulty, then return to this procedure. See Locate a Faulty DIMM.
If you installed a new DIMM to increase functionality, go to Step 4.
-> show /System/Memory/DIMMs /System/Memory/DIMMs Targets: DIMM_x DIMM_y ... ->
where x, y, or so on, is the slot number where the DIMM is installed.
-> show /System/Memory/DIMMs/DIMM_x
where x is the slot number where the DIMM is installed.
