You must determine if the PDB is faulty before you replace it.
-> show /System/Power /System/Power Targets: Properties: health = OK health_details = - ... ->
If the health_details property identifies a faulty PDB, replace it. See Remove the PDB.
If the PDB is faulty, you will see /SYS/PDB under the Value heading.
For example:
-> show faulty Target | Property | Value --------------------+------------------------+------------------------------- /SP/faultmgmt/0 | fru | /SYS/PDB ... ->
If the PDB is faulty, replace it. See Remove the PDB.
If a FRU value different from /SYS/PDB is displayed, see Component Service Task Reference to identify which component is faulty.
See Display Faults (faultmgmt Shell).
Check the Fault class and Description fields for more information.
-> show /SYS/PDB/T_IN_PSx value /SYS/PDB/T_IN_PS Properties: value = 26.000 degree C ->
If an unreasonable temperature or no temperature is displayed, replace the PDB. See Remove the PDB.
