Removing a CPU is a cold-service operation. You must power off the server before you remove the CPU.
See Locate a Faulty CPU.
If you have not prepared for service, do so now. See Preparing for Service.
If you are removing a CPU as part of another component's removal or installation procedure, go to Step 3.
See CPU Configuration.
Alternate between the screws in an X pattern, turning each 1 revolution, until they are fully removed.
This action breaks the adhesion of the heat sink to the CPU.
![]() | Caution - Do not pull forcibly as you might damage the heat sink or CPU socket. |
The triangle on the side of the tool aligns with pin 1 of the CPU.
You hear a click, and the release button retracts.
See Install a CPU.
