To run diagnostic and troubleshooting command outside of the OS and host console, you must first access the SP and log on as a user recognized by the SP.
SER MGT – Connect a terminal device (such as an ASCII terminal or laptop with terminal emulation) to the serial management port.
Set up your terminal device for 9600 baud, 8 bit, no parity, 1 stop bit, and no handshaking. Use a null-modem configuration (transmit and receive signals crossed over to enable DTE-to-DTE communication). The crossover adapters supplied with the server provide a null-modem configuration.
NET MGT – Connect this port to an Ethernet network. This port requires an IP address. By default, the port is configured for DHCP, or you can assign an IP address.
The Oracle ILOM default username is root, and the default password is changeme.
% ssh root@xxx.xxx.xxx.xxx ... Are you sure you want to continue connecting (yes/no) ? yes ... Password: password (nothing displayed) Oracle(R) Integrated Lights Out Manager Version 3.2.4.0 SW1.0 r93491 Copyright (c) 2014, Oracle and/or its affiliates. All rights reserved. Warning: password is set to factory default. Hostname: ORACLESP-489089M+1436BV0010 ->
The Oracle ILOM prompt indicates that you are accessing the SP with the Oracle ILOM CLI.
