Oracle ILOM Legacy Targets for LED States
Use the Oracle ILOM show command with these targets to display
the states of status LEDs for hardware components. See Display Component LED State.
Note -
You can enable the Locator LED to blink with the set /SYS/LOCATE
value=Fast_Blink command.
Locator
/SYS/LOCATE
Chassis Ok
/SYS/OK
Chassis Service
/SYS/SERVICE
CPU Px Service
/SYS/MB/Px/SERVICE
where x is either
0 or 1
Drive HDDx Ok to Remove
/SYS/DBP/HDDx/OK2RM
where x is 0 to
7
Drive HDDx Service
/SYS/DBP/HDDx/SERVICE
where x is 0 to
7
Fan module FMx Service
/SYS/MB/FMx/SERVICE
where x is 0 to
4
Power supply Fault
/SYS/PS_FAULT
SP Ok
/SYS/SP/OK
DIMM Dy
/SYS/MB/Px/Dy/SERVICE
where y is 0 to
11, and
x0 or
1
Critical alarm
/SYS/CRITICAL_ALARM
Major alarm
/SYS/MAJOR_ALARM
Minor alarm
/SYS/MINOR_ALARM
User alarm
/SYS/USER_ALARM
