Check to see if any System Service Required LEDs are lit or flashing.
See Interpreting Diagnostic LEDs.
In Oracle ILOM, check the health of the CPUs.
Replace x with 0 or 1 in the dual-processor
configuration. The CPU is always CPU_0 in the
single-processor configuration.
-> show /System/Processors/CPUs/CPU_x
/System/Processors/CPUs/CPU_0
Targets:
Properties:
health = Service Required
Run the show faulty command.
See Display Faults (show faulty Command).
Use the Oracle ILOM faultmgmt shell to identify the
faulty component.
See Display Faults (faultmgmt Shell).
Run UEFI CPU diagnostics.
Refer to the Oracle x86 Servers Diagnostics, Applications, and
Utilities Guide for Servers with Oracle ILOM 3.1 and Oracle ILOM
3.2.x at http://www.oracle.com/goto/x86AdminDiag/docs for
information.
If you are unable to determine if a CPU is faulty, seek further
information.
See Detecting and Managing Faults.
