After you install the PDB, you can verify its functionality.
-> set /SYS/PDB clear_fault_action=true Are you sure you want to clear /SYS/PDB (y/n)? y Set 'clear_fault_action' to 'true' ->
-> show /SYS/PDB/T_IN_PS value /SYS/PDB/T_IN_PS Properties: value = 23.500 degree C ->
