Installing the USB board is a cold-service operation. You must power off the server before installing the USB board.
If you are replacing the USB board, remove the faulty or obsolete USB board first, then return to this procedure, Step 4. See Remove the USB Board.
If you are installing the USB board as part of another component's removal or installation procedure, go to Step 4.
The USB connectors are forward and upward.
If you installed the USB board as part of a replacement operation, go to Step 8.
If you installed the USB board as part of another component's removal or installation procedure, return to that procedure. See Component Service Task Reference for assistance.
