Oracle ILOM Log Entry Filters
When you display the Oracle ILOM log, you can filter the output to specific
classes and types of entries using combinations of the
Class and Type parameters. See
Display Oracle ILOM Log Entries. This table describes the combinations and
the entries that are displayed.
Class==Audit Type==Log
Commands that result in a configuration change. Description
includes user, command, command parameters, and success or
failure.
Class==IPMI Type==Log
Any event that is placed in the IPMI SEL is also put into the
management log.
Class==Chassis Type==State
Changes to the component inventory and general system
state.
Class==Chassis Type==Action
Shutdown events for server chassis, hot-insert and -removal of
components, and Reset Parameters button when pressed.
Class==Fault Type==Fault
Fault management faults. Description gives the time fault was
detected and the suspect component.
Class==Fault Type==Repair
Fault management repairs. Description gives the component
name.
You can further filter the output with the Severity
parameter. The Severity parameter has one of five
values:
Debug
Down
Critical
Major
Minor
For example, to display only log entries indicating a minor change to the system
inventory, type:
-> show /SP/logs/event/list Class==Chassis Type==State Severity==Minor
Note -
The Critical, Major, and
Minor values for the
Severity parameter do not necessarily corollate to
the Critical, Major, and Minor alarm states.
