If Oracle ILOM detects a fault and consequential component replacement, Oracle ILOM automatically clears the fault. However, if the host detects a fault, you must manually clear the fault from Oracle ILOM after resolution by resetting the component.
-> set target clear_fault_action=true
where target is the Oracle ILOM target of the faulted component.
See Resettable Targets for a list of targets.
For example, to reset and clear a fault with power supply 0:
-> set /SYS/PS0 clear_fault_action=true Are you sure you want to clear /SYS/PS0 (y/n)? y Set 'clear_fault_action' to 'true' ->
