-> show /SP/logs/event/list Class==class Type==type
where class and type are chosen from the table in Oracle ILOM Log Entry Filters.
For example, to display log entries pertaining to faults:
-> show /SP/logs/event/list Class==Fault Type==Fault Event ID Date/Time Class Type Severity ----- ------------------------ -------- -------- -------- 1741 Tue Mar 6 20:13:05 2012 Fault Fault critical Fault detected at time = Tue Mar 6 20:13:05 2012. The suspect component: /SYS/PS1 has fault.chassis.power.ext-fail with probability=100. Refer to http://www.sun.com/msg/SPX86-8003-73 for details. ->
For this example, power supply 1 had a fault. A URL is provided for more information about the fault.
