Removing the USB board is a cold-service operation. You must power off the server before you remove the USB board.
If you have not prepared for service, do so now. See Preparing for Service.
If you are removing the USB board as part of another component's removal or installation procedure, go to Step 5.
If you removed the USB board as part of a replacement operation, install a new USB board. See Install the USB Board.
If you removed the USB board as part of another component's removal or installation procedure, return to that procedure. See Component Service Task Reference for assistance.
