Host Managed
(hostmanaged=|) |
Enabled (True)
Enabled (True) | Disabled
(False) Specify the option for configuring the USB Ethernet connection points:
Enabled |True (default) - To enable, select the
Host Managed check box to instruct Oracle ILOM to
auto-configure the link between the SP port and
host-side port on the installed Ethernet-over-USB
interface.
Note -
Disabling the Host Managed property
(hostmanaged=false) after an
internal management connection is auto-configured
by Oracle ILOM will automatically cause all the
host applications running on the auto-configured
internal management connection to fail.
Disabled | False - To disable, clear the Host
Managed check box to instruct Oracle ILOM not to
configure the link between the SP port and host port
on the installed Ethernet-over-USB interface. When
the Host Managed check box is set to False, advanced
network administrators can optionally configure the
Ethernet-over-USB connection manually.
Single SP CLI Syntax
set /SP/network/interconnect
hostmanaged=true|false
CMM-Blade CLI Syntax
set /Servers/Blades/BL/network/interconnect
Multi-Domain SP CLI Syntax
set
/Servers/PDomains/PDomain_n/SP/network/interconnect
hostmanaged=true|false |
State
(state=) |
Disabled |
Enabled | Disabled
(default) When the Host Managed property is set to False (check box is cleared), specify one of the
following State modes:
Disabled (default) - Clear the State check box to
disable the Local Host Interconnect (USB Ethernet
link interface) feature in Oracle ILOM
Enabled - Select the State check box to enable the
Local Host Interconnect (USB Ethernet link
interface) feature in Oracle ILOM.
Note -
If you choose to manually configure the
Ethernet-over-USB connection points between the
host OS and the Oracle ILOM SP, the value for this
property must be set to enabled.
state=enabled|disabled
set
state=enabled|disabled |
IP Address
(pendingipaddress=) |
169.254.182.7 |
When the Host Managed is set to False, you can optionally
modify the non-routable IPv4 address for the service
processor USB Ethernet connection.
Note -
By default, Oracle provides non-routable IPv4
addresses for each connection point (ILOM service
processor and host OS). Do not change these addresses
unless a conflict exists in your network environment
with the provided non-routable IPv4 addresses.
Netmask Address
(pendingipnetmask=) |
255.255.255.0 |
When the Host Managed check box is set to False, you can
optionally modify the network mask
Note -
You typically will not need to change the
preconfigured IPv4 Netmask (255.255.255.0) address,
unless a conflict with this address exists in your
network.
CLI Syntax
set
pendingipaddress=specify_new_address
set
pendingipnetmask=specify_new_address
Allowed Services
(allowed_services=)
Fault-Transport, IPMI, SNMP
Fault-Transport, IPMI, SNMP (defaults) | HTTP, HTTPS,
SSH
Note -
The Allowed Services property is available for
configuration as of Oracle ILOM firmware version
3.2.6.
modify the list of allowed communication services. Any
combination of services is allowed.
Web - Allowed
Services
To enable a single communication service, click the name
of a communication service in the list. To enable multiple
communication services, press the Ctrl key as you click the
names of the communication services in the list. To disable
one or more communication services, press the Ctrl key as
you click the names of the highlighted (enabled)
CLI Syntax - Allowed
Services
Single SP CLI example:
allowed_services=fault-transport, http,
https, ipmi, snmp, ssh
Save
(commitpending=true|false) |
Any modifications made to
IP Address or Netmask Address for the Oracle ILOM SP Ethernet-over-USB connection
point are considered pending until the changes are committed in
the CLI or saved in the web interface.
CLI Syntax
set commitpending=true |
Service Processor MAC Address
(spmacaddress=) |
Read-only |
The read-only property for
the Service Processor MAC Address displays the MAC address that
is assigned to the Oracle ILOM SP. |
Host MAC Address (hostmacaddress=) |
Read-only |
the Host MAC Address displays the MAC address that is assigned to
the managed server and it also represents how most operating systems recognize
the internal Ethernet-over-USB interface. |
Connection Type |
Read-only |
This read-only Connection
Type property indicates the connection type of the internal USB
Ethernet. |
CLI help command |
For additional information about configurable or non-configurable properties appearing under
the /network/interconnect CLI target, you
can type the help command followed by the
property name.
Syntax:
help /SP|CMM/network/interconnect property_name
Example:
help /SP/network/interconnect hostmanaged |
More details ... (web help)
For additional information, click the More details link in
the Local Host Interconnection section of the Connectivity
> Network page.
