Resolving
Connectivity Issues
If you are experiencing difficulties establishing a network
connection to Oracle ILOM interfaces, refer to the following IPv4
and IPv6 information for suggested resolutions.
Table 52 Troubleshooting IPv4 Connectivity Issues
Unable to access Oracle ILOM
using IPv4 from a network client. |
Ensure that the setting
for State is enabled on the Network Settings page in the Oracle
ILOM web interface or under the /SP/network target
in the Oracle ILOM CLI. Other suggestions for diagnosing IPv4 network
issues, include the following:
Verify that a LAN
connection to the physical management port (NET MGT) is established.
Verify that the appropriate network service, in
Oracle ILOM, is enabled: SSH, HTTP, or HTTPS. In the web interface,
click ILOM Administration > Connectivity to verify and change network
connectivity settings.
Use an industry-standard network diagnostic tool
like IPv4 Ping or Traceroute to test the network connection to the
managed device.
Run ping from the web or the CLI. Or, run traceroute from
the service Oracle ILOM restricted shell.
Table 53 Troubleshooting IPv6 Connectivity Issues
Unable to access the Oracle
ILOM web interface using an IPv6 address. |
Ensure that the IPv6 address
in the URL is enclosed by brackets, for example: https://[2001:db8:0:0:0:0:0:0] |
Unable to download a file using
an IPv6 address. |
load -source tftp://[2001:db8:0:0:0:0:0:0]/desktop.pkg |
using IPv6 from a network client. |
If on a separate subnet,
try the following:
If on the same or a separate subnet, try the following:
Ensure that the property for IPv6
State is enabled on the Network Settings page in the Oracle ILOM
web interface or under the /SP/network/ipv6 target
In the web interface, click ILOM Administration > Connectivity
to verify and change network connectivity settings.
like IPv6 Ping or Traceroute to test the network connection to the
managed device.
Run ping6 from the web or CLI. Or, run traceroute from
