Before You Begin
Review the Requirements for BIOS Configuration Tasks
Follow these steps to reset the Oracle ILOM configuration and the host BIOS configuration to factory defaults from the Oracle ILOM CLI or web interface.
From the web interface, click Host Management > Power Control > Power Cycle.
From the CLI, type: stop -force /System
From the web interface, click System Management > BIOS, then select Factory from the Reset Defaults To Factory list box, and click Save.
From the CLI, type: set /System/BIOS reset_to_defaults=factory
From the web interface, click ILOM Administration> Configuration Management > Reset Defaults, then select Factory from the Reset Defaults list box, and click Reset Defaults.
From the CLI, type: set /SP reset_to_defaults=factory
From the web interface, click Host Management > Power Control > Reset.
From the CLI, type: reset /SP
Oracle ILOM resets BIOS configuration parameters to factory defaults and returns None as the Sync Status state.
