-r redir_type |
The -r redir_type identifies
the type of storage media being redirected.
Valid device values for redir_type include:
CD-ROM device
Syntax: -r cdrom
CD-ROM image:
Syntax: -r cdrom_img
Floppy device:
Syntax: -r floppy
Floppy image:
Syntax: -r floppy_img
-t redir_type_path |
The -t redir_type_path identifies
the full path to where the storage redirection media is stored or
mounted.
Syntax usage example:
-t /home/username/JRC_Test_Images/CDROM.iso |
-u remote_username |
The -u remote_username identifies
the user name required to log in to the Oracle ILOM SP.
-u john_smith
Note - Any valid user account in Oracle ILOM can install or
launch the Storage Redirection service or client on a local system.
However, a valid admin (a) or console (c)
role in Oracle ILOM is required to start or stop the redirection
of a storage device on a remote server. |
-s remote_user_password |
The -s remote_user_password identifies
the password required to log in to the Oracle ILOM SP.
-s my_password
If this password sub-command is not specified at the command
line, the system will automatically prompt you for it. |
-s yes/no |
The -s yes/no
option instructs the storage redirection service to accept the
server security certificate in the case that the certificate is
not trusted by the storage redirection service. If this option
is not specified, in the case that the certificate is not
trusted, the system will automatically prompt you for it. As of Oracle Firmware 3.2.5.3, the -s yes/no
option applies when issuing the Start and
Stop sub-commands.
Syntax usage examples:
-s yes
or
-s no |
-p storageredir_port |
The -p storageredir_port identifies
the storage redirection communication port on the local host. The
default port provided is 2121.
-p 2121 |
