Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 4.0.x
Exit Print View
Updated: July 2020
Zone Management Using a Third-Party In-Band Management Application
If your environment supports managing access to chassis-level storage devices using a third-party in-band management application, you should verify that the state for the Sun Blade Zone Manger in Oracle ILOM is disabled (default). If you need to reset the in-band management password to factory defaults, you can reset this password in Oracle ILOM. For instructions, see Resetting the Zoning Password to Factory Default for Third-Party In-Band Management .
